https://www.google.com/search?q=p0441+dodge+ram&ie=utf-8&oe=utf-8&client=firefox-b-1-mJust got this code on my 2014 5.7 with 96K miles P0441
Can anyone give me parts and DIY fix for this?
Check gas cap 1st.........thx KeepRight, I have been reading about general info on this but was hoping for some specific hemi owner information about specific fixes...
from what I see it may go away... on a recent 300 mile trip I found it odd that on startup, twice or three times the engine idle was terrible for the first 30 seconds, but chaulked it up to damp weather... does not seem to have been a problem in the last week, but yesterday threw the CEL and read the code this morning...
I reset the code and hope it will go away for good
PS I did a search on forum but only saw one unanswer recent thread on same problem
Dear God in heaven.......my next truck will have a carburettor and a manual transmission. And not one, single computer..............Incorrect purge flow. That's the definition of that code. You can throw parts at it based upon advice here (shotgun repair) but that can get real expensive.
Perhaps it would help you if you understand the strategy for setting that code and what the ole computer is up to when that code rears its ugly head. Here's a simple generic explanation... Gasoline is a hydrocarbon. Plain and simple. That means it easily changes sate from liquid to gas for a simple explanation... so.... you go to the gas station and gas up in the cool of the day.... and go park in a hot parking lot for the day. That gas will expand greatly and some will off gas and have to go somewhere besides the atmosphere.... and that would be the charcoal canister, where it condenses back into liquid and is held until the computer commands several things needed to burn off those excessive hydrocarbons. The first thing that happens is the computer will command the vent valve to close. Next it will take a reading from the fuel tank pressure sensor and compare the vacuum buildup into a digital voltage signal. Computer will compare that signal to the one programmed into it's files to insure system integrity or that the cap hasn't been left loose..... and if that's ok, will command Purge valve operation in order to suck that extra fuel into the engine and burn them off. During Purge, the computer monitors the rate that the tank pressure signal goes down and compares that to it's programmed parameters.
If the FTP (fuel tank pressure) sensor signal does not match what's in programmed parameters, the computer logs a "Pending DTC with one or more EVAP DTC's. Because it is a "B" code, the computer must see the problem again within a programmed number of failures during subsequent drive cycles. That way, if all you did was leave the gas cap loose, you might add more fuel before that happens and the pending code disappears and the check engine light doesn't come on.
Most often the gas cap is loose or bad with this stand alone code.
I respectfully disagree sir....plenty of beautiful, old, trucks still for sale in the US of A. Plentymaybe in Heaven, not the the US of A... but I'm with you
wow that just happen to me and your going to laugh how I fixed it ! had gas cap problems few times and this time I look at the o ring on my cap was flatten over the years so I carefully got ring off use little oil cleaned it up use the good side of ring on top when in then tested truck the code went a way never came back ! almost got a new cap again like years a go !Just got this code on my 2014 5.7 with 96K miles P0441
Sent from my XT1650 using Tapatalk
