- Nov 2, 2020
- 10,231
- 13,003
- Location
- El Cajon Calif. 92021
- 2016
- 3.0 ecodiesel
Batram, did you live down under, NZ, or Australia a few years back
Just curious
Just curious
I'm having a similar battery drain issue as others yet different. If I leave my '13, 1500 for 5-6 days the battery will be completely dead and truck won't start. At the same time, it's currently -30c outside and the truck starts fine without even being plugged in (as long as I drive it every day). I pulled the negative cable and tested it. It's drawing over 3 amps when shut off. I tried pulling all the fuses and nothing seemed to make a difference with the amp draw. I've read that the fuel pump relay can be an issue and is soldered into the bottom of the TIPM so can't be tested without removal of the TIPM. The battery is less than a year old and I don't hear any noises coming from anywhere when the truck isn't running. Any thoughts?
Batram, I had an erratic 3 to 4 amp draw and erratic dead dual batteries in my 2020 RAM 3500 from the first months I owned it. I wasted a number of trips to 5 dealers trying to get the erratic draws identified. It turned out to be the batteries themselves! Stellantis assigned a Star engineer. (not so stellar).,. They initially only documented the draw from one of the batteries and replaced it. That worked for about a month and then the problem recurred. I replaced both batteries myself and it has 100% solved the issue. I never would have anticipated batteries could have some kind of intermittent internal short. Anyway, be aware than even my new batteries had some kind of internal problem.
Last time I have been in the place.Load testing is free and always provides valuable insight into the true status of a battery's capability and life expectancy.
I thought it was free , until I went to my local dealer where I bought the car new, and a new battery from them 25months ago, it was OK and wrote a service bill for 35.oo 10.oo, I could live with that.
