ramchuck
- Joined
- May 13, 2016
- Posts
- 11
- Reaction score
- 3
- Location
- Shadyside, Ohio
- Ram Year
- 2010
- Engine
- 5.7 Hemi
I have a 2017 2500 Limited diesel. It has been well cared for and all services have been performed. Currently has 93,000 miles, and has done minimal towing. My issue is when the transmission downshifts there is a "clunk" in the rear end. I put the transfer case in neutral and you can rotate the rear driveshaft and see the "slop" in the rear end. There is no other noise, the diff lube looked good, so what do you think needs done. Can the differential be re-shimmed, or simply is it worn out and need replaced?
Chuck
Chuck
