Running hot randomly after new water pump
Ramrob20
Lake Tahoe
The water pump went out 3 months ago on my 2014 Ram Hemi at about 135,000. I replaced it with a MOPAR pump, thermostat and coolant. Prior to it going, the truck would run about 199-203 and since replacing it, it runs about 204-208. And it will also randomly run all the way up to 221 until the aux fan kicks in and it comes back down.
What is making it run hotter than before?
There doesn't seem to be any air in the system, but how am I sure? I did not replace the clutch fan as it seemed to be functioning properly, could that be it?
Pic of temps from this morning.
DILLIGAF
Canada
The fan clutch should've never been put back on ;)
Might just be a slight variation from one Thermostat to the other or Still a bit of air in the system.
Burp it gain just as a precaution.
DILLIGAF
Canada
I mean you dont need it. :headbang: :headbang: Tons of folks on here just delete it without even doing the V6 fan swap.
Burn2k12Ram
Reno, Nevada
What t-stat did you go with? Those have been known to be bad new. when up to temp take a temp gun and measure the temp of the top hose and bottom. Will tell you if it is opening properly or not.
R
Ramrob20
Lake Tahoe
It was a Mopar brand. I could try a new tstat. What should readings relatively be with a temp gun on the hoses?
EDIT: At idle and truck up to temp (203*) the top hose is ~155* and the bottom hose is ~110*
Dean2
Near Edmonton
Tells you the T-stat is closed at 203 or the upper hose would be 203. What does the T-stat area around the housing read before the T-stat. My 2021 2500 has a 215 Degree thermostat, actually says 102 Centigrade, so it won't normally open till the coolant hits that temp. That is without getting into the whole electronic opening stuff on them.
RedSRT4Me
Scottsdale, Az
2015 CC Sport
Still have air in the system. Bleed the system and get the air out.
Dodge 1500 4X4
Rochester, NY
Remove the radiator cap and squeeze the upper hose several times, also put your heat inside truck on High to get the antifreeze to flow through heater core that may help in burping!!
R
Ramrob20
Lake Tahoe
Did some troubleshooting this morning. Ive determined that I don't think the thermostat is opening, let me know if you agree.
1. Confirmed no more air in system (best I could).
2. Filled reservoir tank to correct height (it was empty)
3. Let truck idle with radiator cap off and heat on.
4. Truck idled until it reached 206*
At this point the radiator overflowed out of the cap and all over the floor. The top hose measured 160*, the bottom hose was 110* and the thermostat housing was 150*.
This leads me to believe the thermostat is not opening correctly and is also probably getting stuck closed during the times it reaches 221*.
Agree?
danielmid
Southeast WI
2015 Sport 4x4
I would tend to agree with your testing and thought process. Parts stores should have the Stant or the Gates in stock, you can drop the temp from the OEM rating as well, like the 190 or even the 180.
Dean2
Near Edmonton
Agree?
Something wrong with these numbers. 1st leave the rad cap on the radiator. The system needs pressure to operate right. If your dash is saying 206 and the thermostat housing is saying 160, what is the temp on the motor side of the thermostat, as in before the water goes through the T-stat. It should be 206 if your truck gauge is correct. If it isn't your sensor or gauge is defective.
If the Thermostat is not opening, then the Radiator should never have overflowed, otherwise where did the overflow coolant come from?
The cooling system in your truck is really pretty simple, it should not be anywhere near this difficult to figure out what is going on.
Simplified picture of how the coolant flows.
R
Ramrob20
Lake Tahoe
The radiator cap was off so that any air burped when the thermostat opened. And yes I agree the thermostat did open, hadn’t had enough coffee this morning when I typed that. I guess this thermo just opens a little hotter than the other.
Still don’t know why it’s jumping up to 221* randomly when driving the same routes I always do.
Temps I took just now.
Dash reading:
Top hose:
Bottom hose:
Thermostat:
Water pump:
RedSRT4Me
Scottsdale, Az
2015 CC Sport
Dash reading:
Top hose:
Bottom hose:
Thermostat:
Water pump:
Those temps seem normal with a stock thermostat with + or - in manufacturing tolerance. Likes other suggested you could always get another.
Administrator
Using an infrared thermometer is great for reference purposes but they can be really inaccurate especially when reading through a moving air stream. Couple that with your trying to read through rubber(it's an insulator).
Stick a surface probe on the top of the thermostat housing and/or the metal part of the radiator as close to the upper hose as possible.
Green_Manalishi
You won't properly burp it with the cap off. You need to burp it a the pump. My apologies if you have already done so.
Dodge 1500 4X4
Rochester, NY
He was sitting still at idle, no air flow. Unless the fan kicks in that reading is about right.
He wasn't doing it through the air stream of the cooling fan, He still should have got a lower reading using a infrared gun, they are the most accurate, A temp prob who has time to read it!!!, also that heat at idle is the best time to check it, with no cooling going on!!!!
Freakydude
ontario canada
Ecodiesel
If the air is out then I would change thermostat. Its going to be your best shot at a simple fix. could be a sensor as well?
