Seat swap wiring
Matthew Smith
Georgia
I recently swapped out my 2012 manual seats with seat out out a 5th gen 4500. The seat bolted up and everything and one plug fit. One of the plugs is different than the one of my truck. My seat belt light is on only is there anyway to disable it or anything. The donor seat was manual as well
Matthew Smith
Matthew Smith
Georgia
Is there a diagram or anything so I know which wires to splice together
jws123
nj
Just swap the wiring over from the other seat? if its manual not much to it.
Ashton
VA
'18
Most likely the buckle causing this. The 09-12 ram are differently wired compared to the 13-18/classic rams. The Hd 5th gens apparently use the same seat bases but unsure of the wiring diffences. Looking into myself actually too. Do you have a pic of the harness?
AKJeeper
