- Joined
- Apr 28, 2012
- Posts
- 23,970
- Reaction score
- 47,103
- Ram Year
- 2010 Hemi Reg Cab 4x4
- Engine
- Hemi
wow, great result, hope it holds up!
Length laws changed to 70 feet long. Back when I had that truck the law was 55 feet front bumper to end of trailer.International was huge in cabovers, dad had 3 at his workplace.
Not sure if bridge weight load formula changed or loads got heavier to make these go away.
Western Star is now owned by Daimler, and little by little they are being standardized with Freightliner components.Back when I was in the wild for Mobil, popular logging truck was Western Star with dual trailers. They mostly hauled pulp sticks in those days since they'd cut most of the saw logs long ago. With paper going out of business, saw logs are making a slow comeback.
Western Star has higher capacity parts, I was told. We don't run cabovers in the U.S. anymore - they lower the load allowed per U.S. DOT bridge formula. Almost all truck tractors are engine out front here.
Bob tailing nightmare
The filter is part of the pan on the 8 speeds so you have to change the whole pan. Went back with a Mopar pan because it still has a year of powertrain warranty left.No filter change?
God luck with the rest of the fluid
I just got 4.5 qts in it following Ricks sheet. It was completely dark out and I was just too tired to do it last night.I believe this is the first time I've read about anyone having an issue
completing a fluid change in the 8-speed when following the WildOne/ZF
directions.
I hope all goes well and you complete the change-over, and hopefully without
having to tilt anything. That would worry me.
That's about right for the Jeeps version of the transmission.I haven't done one,but i've heard a few guys say the Jeeps take about a quart less then the trucks take. Can you post a pic of your old pan Hemi, i'm guessing it uses a physcally smaller pan,to gain a bit more ground clearanceI just got 4.5 qts in it following Ricks sheet. It was completely dark out and I was just too tired to do it last night.
So I got 4.25 qts out and put 4.5 back in. Should be right because I'm sure the filter soaks up a good amount and I spilled some too...
Thanks again @Wild one !
Yeah everywhere i read about doing this on a Jeep GC said about 4.5 quarts so i should be good.That's about right for the Jeeps version of the transmission.I haven't done one,but i've heard a few guys say the Jeeps take about a quart less then the trucks take. Can you post a pic of your old pan Hemi, i'm guessing it uses a physcally smaller pan,to gain a bit more ground clearance
The pan does look differant,as it doesn't have a dropped sump,like the truck pans haveYeah everywhere i read about doing this on a Jeep GC said about 4.5 quarts so i should be good.
Here's a couple pics of the old pan. New one is the same PN but a B at the end and no drain plug so that will be fun next time. I'm thinking of drilling a small hole in the an where the filter is when I go to change it next time.
View attachment 550392View attachment 550393View attachment 550394
Kind of, theres a spot thats round you can see through the cooling finsIs there a boss on the new pan where the plug was located on the old, for reference?
I just looked it up, the truck pans are a completely different PN so that has to be where the extra quart is...The pan does look differant,as it doesn't have a dropped sump,like the truck pans have
