Tailgate off -> no camera -> bright blue screen on 8.4" radio display :(
lpennock
Army
Phoenix, AZ
5.9L & 6.7L Cummins
If you are able to pin connectors I can tell you how to add a camera pigtail to the dummy plug you are currently using to cap the existing wiring. I did this on my 2018 to provide a 3.5mm dc plug and rca plug to use the cheap license plate back up cameras you can get off amazon/ebay. It isn't hard but you have to disassemble the dummy plug add 4 pins to it and reassemble it. I would take me a bit to get all the information gathered up so unless you are comfortable and have the tools I don't want to spend the time.
lpennock
Army
Phoenix, AZ
5.9L & 6.7L Cummins
You should also be able to use the Cab and Chassis kit with bed off removal pigtail.
Pickup Camera Adapter 82215671AB
Camera 56038978af
10ft cable 68200274aa
  • Ram_HD CC_Back Up Camera_2013+.pdf
silverPolarBear
silverPolarBear
New York
Hemi MDS 6.4 GAS
LBussy
Dirt Road, Kansas
Cummins 6.7 HO
I had the same experience with that "plug" as you did. I recently had a local radio shop add the cargo camera (on the 3rd brake light) (2023 3500 Laramie), so there are parts out there for it. I don't recall what they said they had to do, but there were a couple of tries at different parts. It did take an ECU dongle-type fix to update the (I forget what it's called, body control unit?) to make it work, but it all functioned on the display.
I have not removed my tailgate since doing this, so I cannot say what effect, if any, it had, but I'll follow your thread to see if you get that figured out and how. Why I had my tailgate off, coincidentally, right after a trip with my 5th-wheel RV is not important right now.
