SDBIGSHOW78
- Jan 17, 2019
- 1
- 0
- Location
- Evans
- 2021
- 6.7L I6 Cummins Turbo Diesel
I put a 3" leveling kit on my 2021 Ram 2500 Bighorn Deisel 4x4, put aftermarket 20" rims and 35" tires on it. When I went to work, one front tire went out, then the other. drove back to the tire shop. pulled up the tires on their scanner and show they are reading fine. Drove 4k + miles same issue. Took it back and had the tires rotated and the scanner still shows that all 4 tires are reading. and here is the odd part. The two front tires moved to the rear, and they work. the two back tires moved to the front same issue, not picking up the front tires. Drove 15 miles are so about 40 MPH and no changes. tires in the rear position have no problem, so I wonder if the leveling kit could affect the range or something. Thanks for reading my post and let me know if you have any ideas.
