2016 Ram Big Horn 5.7 Voltage Drop
I have a drain on the Battery since I've owned it but don't run the vehicle often so I keep a trickle charge on it. Any ideas what might be causing the drain? Any recommendations on tests would be appreciated.
Any idea of the drain in amps? It is normal to have a small drain on the battery but that number is typically small, less than 250 milliamps at times.2016 Ram Big Horn 5.7 Voltage Drop
