Water Collecting in Bed
mtofell
2014, HD 2500 original owner. For the first 10+ years I had my truck I parked on a slight nose-high spot but have recently moved to a slight nose-low spot and water is collecting in the front of the bed. The truck often sits for days or even a couple weeks without being driven which doesn't help. I have a soft tonneau (no, I'm not spending 2K on a hard, water-tight cover) that ultimately lets a little water in. Anyone ever drill a couple holes in the front of the bed for drainage or have any other great words of wisdom?
And yes, I realize if I park the other direction it won't be a problem.
mdc1990zr1
Conshohocken, PA
I would check your bed, on all my trucks of the big three, there are already drain holes. Maybe yours are clogged?
M
mtofell
Awesome... thanks! Yeah, it's funny, even with parking to drain back it seems I would have got water at some point over the 12 years.
Docwagon1776
Midwest
There's little slots about 1/3 of the way over from either side. As others have said, yours may be plugged (or if you have a spray in maybe they coated over them?).
You don't need an expensive bed cover or even a hard cover to be near water tight. A cheap tri-fold and a tailgate gasket has always worked for me.
