What are those things
BuzzMe
Maine
3.6L v6
2022 Classic Tradesman 3.6L V6: Trying to ID the two silver boxes on passenger side of fire wall. Someone said they thought one was the PCM (?) but what is the other one right beside it? Being "****", I'd like to label each of them for future reference. Thanks in advance for your guidance.
Fediej
Wisconsin
EcoDiesel
Picture would help us help you.
fireflymedic
Fla.
V6
I have no idea but guessing it has to do with the electric drive system I hear all v6 have now.
B
BuzzMe
Maine
3.6L v6
Finally figured out how to upland pics. SO:
2022 Classic Tradesman 3.6L V6: Trying to ID the silver box with two breakers (?) on passenger side of fire wall. Someone said they thought it's the PCM (?) but what are the two red handle thingys? Being "****", I'd like to label each of them for future reference. Thanks in advance for your guidance.
turkeybird56
Central Texas
ECU for your vehicle. The red clips lock in the 2 adapters that all the cabling/wires going to the ECU.
This Engine Computer also referred to as an Engine Control Module (ECM), Engine Control Unit (ECU) & Powertrain Control Module (PCM) is a guaranteed replacement for all 2020 Dodge Ram Truck 1500 PCM models with a 3.6L engine size.​
What is an ECU in an engine?
An engine control unit (ECU), also commonly called an engine control module (ECM), is a type of electronic control unit that controls a series of actuators on an internal combustion engine to ensure optimal engine performance.
mikeru
Super Moderator
Super Moderator
The Palouse
2020 Limited
Those are not breakers, they are connectors for the wire harness. The red handles lock the connectors in place and you pull the red handles to release them.
B
BuzzMe
Maine
3.6L v6
OK, but what is the silver thing
danielmid
Southeast WI
2015 Sport 4x4
In laymans terms it's the trucks computor,otherwise known as the PCM ,powertrain control module.
turkeybird56
Central Texas
Also sometimes referred to as a ECU, terms used interchangeably. See post #5.
