CaseO
Also what do you recommend?
where are you? Is this a high mileage ram? There is a when to and when not to use redline thread. If there is no hemi tick, I would not go switching to redline in a high mileage ram. Or at least understand the risks.Wish I could get Redline locally.
IMO, yes. If you felt like getting some protection against dry tick or hemi tick, you can opt for some lubeguard biotech, and I certainly would use a spun microglass filter such as royal purple 20-820. If you had hemi tick, you would certainly know it, it isnt exactly something easy to ignore. For sure I'd stick with that oil and use the rp filter, maybe or maybe not go lubeguard. I would invest in a used oil analysis from blackstone if you really want to know the health of the engine and perhaps get some benefit at a different strategy, o make you comfortable with what you are doing, depending on how the numbers ae.I have over 186,000 miles on my Ram and to my knowledge I don’t have a Ram Tick. Should I just stick to the PUP 5w30?
220k hear more like a lower rattle than a hemi tick.where are you? Is this a high mileage ram? There is a when to and when not to use redline thread. If there is no hemi tick, I would not go switching to redline in a high mileage ram. Or at least understand the risks.
That filter didnt make the gm test, and neither did wix xp, the only expereince I has with that filter was my truck ticked on it before it was redesigned. The redesign doesnt look that good either see below graph. Just like the GM test, fram ultra and rp are on the top.Right now I’m using a Boss Purolator and I have another one for the next oil change.
Wix xp and Puro Boss are worse then paper ac delco, that is plain embarrassing.
