WIN Module Replacement options
Montanabadfish
Montana
2012 Dodge Ram 1500...I need a new ignition switch and programed key fob. Dealership wants almost a grand....there has to be companies out there that rebuild these, maybe sell new. Program the fobs to the module and ship them to you? What is the best bang for my buck here?
Jeepwalker
WI
2012 Reg Cab, 4x4
What seems to be the issue? Have you tried cleaning it? There are several Youtube videos about Ram ..and Chrysler, Win modules. Have you checked internet sites (Rockauto, ebay, Amazon, mopar online parts)?
IDK how DIY you are ..or want to be, but you could program your own with AlfaOBD software ..which is ~$50 (plus you'll need a cable).
Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
Yeep, we used alfaobd to program a new fob for @the_goodguy07 's truck a few months ago and it took 5 minutes to do so ...
Hopefully he only needs a new FOB and not the WIN module
I went to a local Mobile Locksmith, who also has a brick & mortar store
The mobile vans were gone, but one of the two gals in the store knew how to use the programmer.
For a new FOB, new cut Valet Key & the programming cost $149.98 & it took less than 30 minutes
I was also told that if i bought in a blank FOB, they would program it for $49.98
Another Locksmith that sell FOBs & program them are
ACE HARDWARE
Tractor Supply, possibly
There is another company, that i have heard of, that may be worth checking out is
Jeepwalker
WI
2012 Reg Cab, 4x4
Pretty sure a 2012 will be on the dash though...
you can bypass it as well, hook up push button to the cig lighter relay, but you need to hide the button cause anyone could start the truck.
JeepWalker, you are likely correct
not sure when the change was made
It may have been when they started using the Push Button Start with Keyless Entry ??
Gary2
S Jersey
The WIN module in my 14 would not unlock so I could remove the Key fobik . It could be turned off with a little force which I did for a while. I eventually bought a new WIN and mounted it . I left the old one hang from the wires until the date came that the dealer said they could program my FOBIKs. , Probably came to less than 200 for WIN and programing . When I arrived at the dealer I reached under the dash and moved the plug to the new WIN and the dealer did their thing . Now with ALFAobd I see no reason to involve the dealer at all . I did take the original WIN apart and resoldiered one wire back on the electric motor that controled the lock part of it . The new one has since went bad so I simply reinstalled my original WIN and all has been well for years .
Richard
2012 1500 sport crew 4x4
Richard
I tried the bypass fairly simple to hookup the engine would crank but not start . any ideas?
DILLIGAF
Canadian Forces
Canada
Just did mine. Its super easy
Would need a lot more info, codes? Crank or canshaft position sensor?
noraa73
