AlfaOBD
tron67j
Maryland
I would say if your tablet is still supported by Android security updates you are good. If you have an older tablet, it might still work but you are at risk of viruses, which could transfer to your vehicle. Unlikely, but possible.
RamDiver
Marlborough, Ontario, Canada
It you have a laptop PC, that works just fine. I use the laptop instead of the phone / tablet. Like the interface better.
I agree with that preference.
Android phones or anything Android are a hideous device to make critical modifications that could be capable of causing significant harm to your vehicle.
That's why I chose to use a Windows laptop pc. I can perform and file screen captures much easier, maintain and update tracking records of all changes, step by step. I can easily open a browser window and lookup online resources without leaving my truck. :cool:
And from my experience, I don't have much appreciation for playing games with Bluetooth connections either, especially on anything important.
I bought an OBDLink SX and connect with a reliable USB hardline connection.
All changes to my truck and creation of backup configuration files are somewhat instantaneous.
YMMV :cool:
RCKable
Virginia
So I am about to start my AlfaOBD journey, plan to do a cluster change, maybe LED's and I saw a video about Windows down that I'd like to do. 2 things I'd like to know.
1)-VIN write when doing the cluster change should the VIN write be done before/after changing mileage/engine hours or do you not even have to worry about it?
2)- I've seen posts about things changing on its own, and having to revert to the uploaded file and going thru everything. So my overthinking brain, questions what if a trim never had the option for windows down, will it not be an option on AlfaOBD, will it just fail when i try, or could it go through but change other items, thinking its a different trim?
Edit: sorry maybe i should've made a thread about this and not a reply to the topic.
RamDiver
I'm new to tweaking with AlfaOB and I don't have any experience with VIN adjustments.
I did successfully set the Global Windows Down feature.
Press Unlock once to unlock, then press and hold Unlock as the front windows drop.
If you let go, the windows will stop lowering, to allow a partial opening.
I've also set the Global Window Up but haven't spent much time testing it yet.
It's supposed to function using the Lock button.
BTW, I use AlfaOBD on Windows. :cool:
RamDiver
There have been quite a few people that have tried the global window up and no one has reported that it works.
Thanks for that info.
I did try it a few times without success but thought maybe I was missing something. I haven't done too much experimentation yet but I'm very pleased with no dropout on the (fog) running lights.
I drive mostly in a rural area, it's nice to see both ditches and tree lines well-lit at night. There are too many creatures bolting from the shrubberies. :cool:
RCKable
Virginia
Thank you. It doesn’t seem like there’s much info about the VIN write and the why/when/what for.
I also have yet to find anyone saying they got the windows up to work, only see the windows down.
Sladerade
North Carolina
Quick question! Does anyone have this Key code policy pdf available to download or the updated version? So when I go in I can show them the proof and have a valid reason on why I need my key code.
teddy Charlery
Baytowb TX
A couple of weekends ago I programmed 2 new FOBs for my 09 1500. Everything worked fine, drove around the block with the new fob in the ignition (originally I only had 2 keys). Parked the truck for the night, went out the next day and it cranks just fine with the aftermarket remote start (runs for the 15 minutes and shuts off like it has for years) BUT when I put the keys in (any of them) it runs for 3 seconds and shuts off. I've looked off and on all week, but I can't really find anything.... The remote start mimics the key freq, so I'm not sure if it's the keys that have gone rogue or if there's ACTUALLY something wrong. It's throwing U0236, as you can see from the Alfa screen shot, it's reading the keys....it's just not SEEING the keys in the ignition. I tried to find a wiring diagram, but the only thing I could come up with was for a 2012 Caravan (bodybuilder doesn't work and I tried downloading the service manual from the Z and I can't get it to open). Anyway, I figured the Caravan would be pretty close in troubleshooting and found (A106) FUSED B+ CIRCUIT OPEN.....but that's all I got to go on.
Good Day,
I have the same issue. Did you get a fix? if so, How did you?
Thanks ahead.
PA Ram
Quakertown, PA
Good Day,
Thanks ahead.
Sounds like it could be an issue with the remote start. I haven't programmed any fobs for my 2017,but I have a plug and play remote start with 4g LTE for phone app connection and had to send it back to the company I bought it from after I did initial programming so they could finalize programming. You only program with whichever key you are using, however all my keys work even though they weren't used in programming as all have the same key code. Would the problem persist if you didn't use the remote start? If so, it's most definitely not the issue. If it doesn't, then the issue is the remote start somehow. Maybe older models have different programming. Mine are the fobs that go into the ignition, no actual key unless I need to unlock the door when battery dies.
teddy Charlery
Baytowb TX
Ok. Thanks mine is a 2012 and i have it setup like yours. After market remote start with LTE. only way the truck runs is with remote start and put either key in the ignition. I only had one key and recently had another key done by a lock smith. I'll try to remove the remote start temporally and give it a try. thanks inadvance
PA Ram
Quakertown, PA
What remote start do you have? I got mine from 12 volt solutions.
hfbroady
United states
3.0L EcoDiesel
Does anyone know if you can use AlfaOBD to change the door locks, so they lock once the vehicle is in gear? Currently, they lock at about 15 MPH.
hfbroady
United states
3.0L EcoDiesel
I got my 4-digit PIN using AlfaOBD.... Under RH (Radio Frequency) scroll way down. There is an option to Read Pin. It worked on my 2015 Ram 1500 ecoDiesel and my dad's 2014 Ram 1500 ecoDiesel. I'm also using MX+.
Hope this helps
Heathen-19
Midwest
Hope this helps
I did the same thing with my 2019 Classic. Needed pin for remote start programming if I remember right.
CumminsCrazed
North Central Iowa
5.9 Cummins 24v
These are what your settings should be that have to do with DRLs:
DRL configuration >optional
DRL lamp location > dedicated
DRL dropout enabled > yes
CBC I/O right dedicated DRL lamp output present> yes
CBC I/O left dedicated DRL lamp output present > yes
LED dedicated DRL present> yes
ECUConfig 3 DRL customer setting enable> yes
CustSetMenu 1 daytime running lights CSM> yes
Trying to get this to work with new morimoto XB housings. I've also got the optional fuse tap run to #66 in the under hood fuse block. Trying to decide if one is canceling the other out or what I need to do to make DRLs work right. Prior I had them working in OEM housings in the turn signals. Truck is a 2017 laramie sport appearance pkg G56 for what it's worth.
