- Joined
- May 2, 2014
- Posts
- 227
- Reaction score
- 358
- Ram Year
- 2021
- Engine
- 5.7 Hemi
...I'd like to see it. What team of idiots engineered this? Is there an aftermarket setup available? My search came up dry.
Cheers
Bob
Cheers
Bob
I was in my neighbor’s brand new 24 Nissan Titan the other day helping him get his Android phone work with Nissan system. The design on the Ram is light years ahead of the Titan. The Titan was not near as functional or laid out well. But maybe I am biased since I got a RAM....I'd like to see it. What team of idiots engineered this? Is there an aftermarket setup available? My search came up dry.
Cheers
Bob
Same thoughts on the Titan. I test drove one before I got my Ram and did not like the infotainment setup at all. Seemed boring and like it was an afterthought. Still waiting on an anchorsaweigh to tell us what he doesn’t about Rams setup.I was in my neighbor’s brand new 24 Nissan Titan the other day helping him get his Android phone work with Nissan system. The design on the Ram is light years ahead of the Titan. The Titan was not near as functional or laid out well. But maybe I am biased since I got a RAM.
Take it out and put in a bench seat then. But, if you didn't like the design, why did you buy the truck...I'd like to see it. What team of idiots engineered this? Is there an aftermarket setup available? My search came up dry.
Cheers
Bob
Troll. Just wanted to throw out a ***** sessionSame thoughts on the Titan. I test drove one before I got my Ram and did not like the infotainment setup at all. Seemed boring and like it was an afterthought. Still waiting on an anchorsaweigh to tell us what he doesn’t about Rams setup.
I might agree with you if he hasn’t been a member here for 10 years.Troll. Just wanted to throw out a ***** session
Really, come on man! I don’t do the trolling thing.Troll. Just wanted to throw out a ***** session
Thanks for clarifying what you didn’t like about the center console.Well, the sliding tray for one. The entire forward under-storage is useless if you have to remove stuff from the tray to slide it back for access. If you need to keep the separator flat between the forward and aft part of the under-storage then stuff that you put in the forward end can slide all the way (or half-way) to the rear and you have to dig for it because the area directly under the middle part is nearly inaccessible.
@Randy Grant : A little presumptuous on your part.
1. When looking for any vehicle (and this is my 7th RAM) you may not know you dislike something until you use it.
2. Not many people I know check the operability of a center storage console before a purchase. It's a center console facrissake, it shouldn't be too complicated.
3. I merely stated that I don't like the design and that it could have been better engineered. NOT that it should put someone off from purchasing the truck altogether.
4. Troll? Is your definition of a troll someone who simply states a dislike or is critical of something? Wow, that's a pretty damn broad paintbrush you have.
Cheers
Bob
Perfect place to store chit U may not need for 6 years, lmao.I will admit that upon first purchase it can take a little getting used to and sorting out. The day I picked up my 23 I laid the purchase papers down inside somewhere in the excitement and when I got home I couldn’t find them. I searched everywhere front, back, between seats, under seats, in glove box, in above glove box storage, in the console lid and tray, etc. Had to go back to the dealer the next day to get a copy of the papers. About a week later I found them down in the very bottom of the console under the tray. But it does have a lot of utility and storage.
@Randy Grant : A little presumptuous on your part.Well, the sliding tray for one. The entire forward under-storage is useless if you have to remove stuff from the tray to slide it back for access. If you need to keep the separator flat between the forward and aft part of the under-storage then stuff that you put in the forward end can slide all the way (or half-way) to the rear and you have to dig for it because the area directly under the middle part is nearly inaccessible.
Cheers
Bob
