2004 Ram doesn't like ot shift into drive
snowplowdog
SE Wisconsin
I have an 04 Ram with the 5.7 in it. Lately when I shift into drive from either park, neutral, or reverse it lags a few seconds and then seems like it goes into gear rather hard. Once it's in drive it seems to run fine. Shifts through the gears fine, has plenty of power, shift when it's supposed to, it's just when you're shifting into drive. I thought maybe the fluid was low but when I checked it, it was fine. Any ideas what might cause this?
Williammoody150
Monroe la
Did you ever get this issue figured out? I have the same year model truck doing the same thing
jws123
nj
Is it when you first start it? I know on older rams if you fire it up and put it right into drive it takes a second better to let it run a min or so.
Williammoody150
Monroe la
No, this is when it is warm as well. I had it started today for a good hour or so and every time I would shift into drive it would delay and shift into Drive hard.
jws123
nj
when is the last time ya changed the trans fluid/filter.
