2019 RAM 2500 6.4 8 SPEED MPH AND SPEED CHARTS vs 6 SPEED
WAKEMASTER
WISCONSIN
I thought I would throw this together quick. This chart compares the new 8 SPD ZF transmission to the current 6 SPD 66RFE transmission.
** I am not able to confirm the exact transmission ratios of the new 8 speed. However I would think that the ratios should be very close to what is on the ZF website for the 8HP75.
**I also assumed a 33.2" wheel in the calculations
** I put this together really quick so....
dbctmc
virginia
Thanks. Does anyone know if the 8 spd is manually shiftable? In the photos I've seen, there is not a "M" setting on the shifter dial.
olyelr
Kewadin MI
If its like the half ton’s, the manual shift buttons are on the steering wheel.
JoeCo
NY
Edit olyelr beat me to it.
Administrator
The Gear +/- buttons limit the highest gear the transmission will shift into, it they won't force an up-shift.
I'd be willing to bet the Tow/Haul mode won't lock out 8th gear either. It's a false rumor that the T/H button locks out gears on the 8spd, it only appears that way because your not going fast enough to warrant being in those gears while towing.
RainDesert
ID
Here's a pic of the gear limit buttons on the new 2019 2500 6.4 on a lot near me.2019ramshifter.jpg
olyelr
Kewadin MI
And isnt that pretty much how any auto tranny in the world works, regardless if it has buttons or a large stick on the column?
Administrator
Some people had the delusion that pushing the Gear + button that it would force an up-shift with the 1500 8spd, it doesn't.
It's good to see Ram states "GEAR LIMIT" on the buttons now.
JoeCo
NY
I just use it to shut off mds, but that being said yes I just put it in 8th and let it work as usual.
