Alpha OBD won't access abs
Flryder
Bradenton, Fl
I purchased Alpha OBD and the OBDLink LX for my 2012 1500. I need to do an ABS bleed after I replace the abs module and pump. When I try to access the ABS function, Alpha OBD gives me a connection failure message after 4 attempts. I can access functions like body computer and instrument panel. I selected the OBDlink LX because it was on the supported vehicle list from Alpha OBD. Would the MX+ dongle solve this problem?
Thanks,
Dan
RamDiver
Marlborough, Ontario, Canada
Thanks,
Dan
Are you attempting to use this LX Bluetooth with an Android phone or tablet?
I use AlfaOBD with Windows and a hardline USB interface, OBDlink SX. I don't trust the Android OS to be suitable for the task.
If the OBDlink LX is listed as suitable for AlfaOBD, you could write to Alexey for support.
[email protected]
And, welcome.gif to Ram Forum. :cool:
CanRebel
Toronto
Thanks,
Dan
No you don't need to change to different OBD connector.
Just to make sure. you changed the ABS module to new one ?
If so, you need to initialization module first. Have you tried that ? Or is that part that is failing ?
You can't do the bleeding until you do the Init.
RamDiver
The OP stated that he can't maintain a connection.
Without establishing and maintaining a successful connection, no changes or alterations will be available with AlfaOBD.
It sounds like he may have access to certain BCM functions via LS Can bus only.
CanRebel
Toronto
He didn't say that.
He said
/Quote
/Quote
If you put a new module, and don't do initialization. You can't connect to it. Which is why I asked him if he did it first.
Revinvoss
Washington
4.7 L V8
I have the same issue with linking up to the ABS, I thought you would have to link up with it to initialize it?
How do you initialize the ABS module?
