Check your intake manifold bolts
Dean2
Near Edmonton
This hasn't been talked about for awhile,but check your intake manifold bolts.They call for 108 in-lbs or roughly 9 ft-lbs of torque,and they should be checked at least yearly,as they do loosen up. I've been doing mine at least twice a year on all 3 of of my hemi equipped vehicles.They should be checked and torqued when the engine is cold.I just use my calibrated hand and a 1/4" drive rachet / 6" extension and 5/16's socket and just give them a twist by hand,but if you don't trust your hand,an inch lb torque wrench should be used.There's 10 of them on 5.7's and 6.4's. I've done them enough,i know the torque sequence ,but if you don't know the sequence it's easy enough to look up
Thank you Wild One. Just checked my wifes Cherokee today. 2020 with less than 30,000 miles. Just like most, they were quite loose. Not finger loose but nowhere near the right torque. Was getting so many turns I thought there was something wrong with my finger torque wrench. Actually dug out the real thing and set them to 11 ft lbs, which was still another 1/4 turn on most of them. Vehicle was runnimg fine, no rough idle etc so be interesting to see if it makes any difference, or they weren't quite loose enough yet to have an impact.
Anybody seen this same pattern on the 6.4?
marine0311
Ohio
Thank you for the heads up. My '15 Ram will be delivered to me tomorrow. I wonder what the odds are the bolts have NOT been checked. This baby has just under 40,000 miles. Just like my marriage, having a Hemi is worth the extra effort to maintain. RedSRT4Me was even kind enough to share the torque pattern. Talk about easy peasey
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
6.4L HEMI
Yupper!
RodRamCar
IdaHO
2022 Longhorn
5.7 4x4 w/ 3.92s
Would putting Loctite on those bolts stop the issue? Or by doing so cause another problem?
This seems less of a bolt backing out kind of issue and more of a design flaw/gasket compressing more and more as time and re-tightening goes on that adding loctite probably won't prevent having to re-do this until there's just so much gasket compressed you have to replace the intake manifold gaskets.
marine0311
Ohio
Good enough reason to keep Loctite on the shelf, and do some simple maintenance from time to time
RodRamCar
IdaHO
2022 Longhorn
5.7 4x4 w/ 3.92s
when and if you do, you should see some of the factory "loctite" i think is orange if you were to back those bolts out. It sounds like nobody accounted for the issue of the intake gaskets compressing to the point the bolts have to be tightened over and over because maybe the bolts backing out isn't really the problem.
marine0311
Ohio
Addressing the problem before the Ram leaves assembly would make too much sense. But then again it seems like every manufacture pushes the problem on down the line leaving the customer to deal with the issue. this is not just Ram or automotive related manufacturers. Every industry deals with issues the same way
W
The wifes 6.4 Challenger has the same problem. I'm in the habit of checking them fairly often,if i can twist a couple by hand with a 5/16" nutdriver,it's time to go over them.
Dean2
Near Edmonton
Was kind hoping that wasn't the case. Wifes Cherokee I can stand on a milk crate and reach easily. My 2500 is so friggin tall a milk crate is needed just to check the oil but I need a step ladder if I have to actually add oil. I am also very unimpressed with the crappy design of the oil cap, it is a big step backwards from just being able to unscrew it. No good reason for lousy access like that, my 96 2500 I could stand on the ground and do both. Checking the intake manifold is going to be a pain in the ass.
HEMIMANN
Minneapolis, MN
6.4L HEMI
Do what I do - get a kid to do it for you. It's kinda expensive, with the amount they eat as payment, though.
W
I have a few step ladders,but i think this 3 step one is my favorite if i need a bit more height then a milk crate provides.
Keep an eye on Crappy Tires sales,as they'll put it on sale every once inawhile.
Dean2
Near Edmonton
Have one of these that I carry in the box full time, good for getting in and out of the box and also makes a good chair. Works good for the engine compartment too.
Like my Dad always said, getting old isn't for pu$$ie$*.
W
Things have changed since i was kid,back then if you offered up a box of beer,you'd have a 1/2 dozen 16 years olds over to change an engine, Food you could always buy at 16,beer not so much,lol
HEMIMANN
Minneapolis, MN
6.4L HEMI
I got a similar one to that - I threatened to get an engine creeper, but the boys caught wind from their blabbler-mouthed mother and threatened me with violence, so I backed off.
For now.
Forsakentalon
Iowa
Oops. Should have re-read instructions again. Retorqued while engine was warm. Only went to 95in-lbs though. Yes, every one was loose took multiple turns to tighten.
2017 1500, 80k miles and 2600 hours.
Thanks for adding another maintenance item. Wife is now complaining I ****** my truck more than I do her. And it's all the fault of you guys!
HEMIMANN
Minneapolis, MN
6.4L HEMI
Yeah, boss - semiannual air filter change last weekend, screws were 1/8 turn loose - with dry loctite left on!!
It was such a PITA to remove them, clean old loctite, apply new loctite, reinstall and torque last time I just said screw it and just retorqued in situ to 108 in-lb. Incredible.
Sure as $hit, engine no long sputters @ idle rpm. Incredible. What a $hitty design.
Davenator
