I don’t see how it’s a stuck relay. He claims to have pulled both out and it kept running. The thing I don’t understand is he says he pulled the 60 for the fan and it kept running which makes me wonder if the tipm is melted or if the fan harness is melted somewhereOr a stuck closed relay. Not unheard of
Yeah, makes no sense. If he pulled the relays, stuff should not be running. Something shorted, melted or sumthing,. Gonna take some troubleshooting. He needs to find him a good ole mechanic that knows how to troubleshoot, not a dealership code reader, LOL> All IMHO...I don’t see how it’s a stuck relay. He claims to have pulled both out and it kept running. The thing I don’t understand is he says he pulled the 60 for the fan and it kept running which makes me wonder if the tipm is melted or if the fan harness is melted somewhere
Not unless something drastic happened, like a meltdown, shorted out TIPM< maybe rodent damage in TIPM (Underneath), hmmmm.If the fan is still running after pulling the relay, and it is the correct relay, the normally open contact on the relay socket in the TIPM will be energized or...
These fans are often switched by pulling a terminal to ground.
Maybe the smart move now is to verify the vehicle model and the correct schematic drawings to understand how the fan is activated.
And best confirm fuse and relay numbers before dissecting the TIPM.
If the correct fuse and relay were pulled, this suggests a significant wiring or TIPM failure, would this be expected on a 2017 model truck?
Needs lots of troubleshooting. Because if the proper relays were pulled, no way under normal circumstances should fan be on.
The fan is not enabled by ground. The positive goes through the tipm relays. The positive would have to be shorted. No other way around it. Here’s a crap wiring diagram. as far as I know there are only 2 relays in the tipm for the fan. One marked high speed. One marked low speed. The tipm itself has internal circuit board with wiring that may be shorted between the relays. I think the relays are wired parallel meaning If you short either relay the fan turns on. If the short is internal to the tipm then a new or refurbished tipm will be needed or that one sent out for repair if possible.But.... if the fan is connected to 12vdc and enabled by a ground to the other terminal and the fan wiring harness were shorted to ground and the wrong fuse was pulled and...
LOL
I think we need a schematic before we're all consumed by the endless possibilities.
When things seem too unusual to be possible, it's time to find the schematic and retrace our initial steps.
Cooling fan never turns off unless 80a fuse is removed. I can remove both relays and the 60a fuse and leave the key off and it still runs.
The new body style v8 sends 12v constant to the fan and uses a signal from the pcm directly to the fan to control the fan. The 2013 and up v6 is the same. 2009-2012 v6 use the 2 relays to turn the fan on. 4th gen v8 use the relays to turn the fan on as well.Wow, FCA is really being cheap with their schematics, it almost looks like an etch-a-sketch drawing.
You have a good memory.
I have no idea of the year of a truck I virtually worked on recently but, I could have sworn this truck always had 12 VDC through the relays and the ECM pulled the other terminal to ground.
The user was confused by measuring 12 VDC on both sides of the fan terminals and yet it wasn't turning. He was not clear on the requirement for a potential difference across the fan terminals versus measuring both wrt to chassis ground.
I can't rule out that I may be mistaken and maybe the 12 VDC was on both sides of the relay and the ECM pulled one terminal to ground, changing the relay state which started the fan. I need a schematic to troubleshoot.
Let's find a real schematic with fuse & relay numbers to be sure we're all on the same page. I found one for the above-mentioned incident.
Call it Divine intervention, an epiphany, or just a thought I had it on my mind this morning when I woke up. What if someone put a fuse in the slot that wasn't suppose to be there to start with. Maybe F1 as shown in RamDiver's photo of the TIPM isn't suppose to have a fuse. This would make sense as the fan was toast and someone was trying to get the fan to run by installing a 80 A fuse to get it going. Without this fuse in place, it would allow the fan relay to work properly and supply power to the secondary fan as needed. I will test this theory today and report back. Sometimes you look at something so long, you can't see the obvious.
