eduardo23
Mexico
So yesterday after starting it the engine stoped after moving like 2 meters so checked the battery and everything and see that one of the copper terminals on the battery broke i tried stick the cables to the main terminal with locking pliers but nothing the cluster and everything works fine also the battery is charged , today i cleaned the starter and still nothing the starter relay is working theres no blown up fuse so now i dont see any burned or short cables from what i have checked, so any theories or solutions are of great help.
ram 1500 2006 5.7 hemi slt crew cab
LoneWolf3574
Which terminal/wire? What do you mean by "engine won't start"? Does it turn over?
Inspect TIPM for corrosion, check for other blown fuses (just because it isn't on the starter relay circuit or the starter, doesn't mean that it won't prevent the engine from starting), check for stored codes.
E
eduardo23
Mexico
i found the problem the pcm short-out so got a new one
zwingsterboss
