electrical issues
  1. S
    BCM Programming 2013 Ram 1500
    So I've got a few electrical issues going on. Couple of codes thrown which just come back once cleared. Such as "Loss communication with door module A". And some other ground issues. Well, took it to the shop and all grounds are good. Tech thinks the BCM is bad. I can't get a new BCM from Dodge...
  2. D
    Still having electrical issues.
    Alright guys, I've been at this for about a year now with this electrical issue. Everything passing the bed of my truck and after that does not work, meaning nothing electrical in the rear is working. I took it to the dealer and they said about $2,000 and that wouldn't even guarantee a fix. I...
  3. E
    2014 Ram Ecodiesel BCM
    I've been having Electrical issues with my 2014 Ecodiesel. Started with the lock button not working on the driver's side door. Not a big deal, buttons wear out. Then my Uconnect would go completely haywire after connecting a call on Bluetooth. Ok Weird. I'd turn the bluetooth off on my phone and...
  4. J
    Water damaged/Flooded, No power to most electronics
    Hey Y'all, This is my first time posting in a forum so apologies for any mistakes with posting. Anyway, I've recently got a hold of a (basically free) 2011 Ram 1500 4.7 from a close friend, and as the title says, it's a flood truck. It was fully submerged for about 8 hours in freshwater during...
  5. jacoblane216
    No door locks whatsoever
    2004 Dodge Ram 1500 5.7 Ever since I got this truck I’ve had to manually lock and unlock it because my power locks don’t function whatsoever Brand new window switches, tried a fcm/bcm I know is good, already have a new ecu from another issue, and checked fuses. Fobs don’t do anything and door...
  6. D
    AC clutch clicking and engine shuts off
    Here's a fun one for you guys. I'm having electrical problems that will cause my 88 d100 to shutoff randomly. With the key turned to on and while running, the ac compressor clutch engages and disengages repeatedly (and clicking from somewhere else). I pulled the ac relay and this still occurs...
  7. L
    4wd drive issue flashes everything but 4wd auto
    Hi I just bought a 2007 ram 1500 5.7 and 4wd wasn't working when I bought it, the dude said he replaced the actuator on the front diff but It was leaking so I decided to warranty the part and put a new one and hopefully it would fix my issue so I just replaced it yesterday and 4wd still doesn't...
  8. D
    Lost 12v constant
    My co-driver thought it would be a good idea to charge a laptop on the auxiliary plug inverter. After about 30 mins I lost power to the plug and basically all other hot 12v systems. Such as that port and trailer breaks. I'm not sure what all doesn't work but essentially everything that was a...
  9. L
    Flickering lights, gauges bouncing! Please help!
    1993 w250- 12V Hi all, I’ve recently run into a problem where whenever I turn my headlights on, my gauge (speedo, volt) needles start bouncing around like crazy. Additionally, whenever I go to turn my turn signals on, both turn signal indicators turn on a flash inside the cab. I noticed the...
  10. I
    Aftermarket Headlights
    I have a set of aftermarket projector DRL headlights that are “plug and play” that come with a resistor and are supposed to plug straight in and work. Well here is the deal. I have plugged them up and the driver side light works and the passenger side doesn’t. They both work until I give the...
  11. G
    Brake light/ electrical issues on 2003 Dodge 1500 "Texas Edition" 4.7L.
    For a good few months just my 2 break lights did not work, but my bed light/ brake light still worked. Then randomly after replacing the Tail Light circuit board they stopped working. My back up and parking lights still work, along with the bed light. I have replaced the bulbs. I have...
  12. AlanBobTM
    Not The Usual Power Door Lock Problem
    My recently acquired 2004 Ram 3500 ST Quad Cab has some electrical anomalies. Here's one that has me baffled. The power door locks lock about 5 seconds after turning the ignition switch to On or Accessory. They unlock immediately after turning the ignition switch to Off. The electric lock...
  13. W
    No power without key
    I got a 2002 ram 1500 2wd quad cab, I replaced the hood but didn’t want the wiring so I cut it without disconnecting the battery, the radio resets every time I start, no obd power without the key, no door lock without key. I checked fuse 51 and it tested good. Changed anyways no luck, is there a...
  14. 2010redram
    12v by shifter not working
    So I just bought a 2010 ram 1500 big horn and the 12v plug in by the shifter is not receiving any power. i checked all the fuses and they were good, checked the cigarette lighter itself and boom no power any ideas on what it could be don’t feel like ripping apart **** and tracing wires of i...
  15. B
    Check Engine Lights/ electrical issue
    Hey guys, I have a 2013 ram 3500 6.7 with 130,000kms. Has been great but started having issues with a bad turbo actuator, it would throw random codes I ended up reading this was from a faulty turbo actuator. Replaced that with a fleece cheetah, had no issues since but it seems whenever I get...
  16. S
    2011 ram 1500 frequent codes
    Hello, I just recent purchased a used 2011 ram 1500 from a dealership. For about the first 2-3 weeks I owned it I had no problems and it was running great. Since this I have thrown multiple codes. Currently, about once a week, I am having to replace a new sensor. The first was a P0457. This was...
  17. F
    P2128 & Heater Issues
    Howdy all. Newbie here. Not a mechanic or anywhere close :) I've got a 2004 Ram Quad 5.7 Hemi. Recently I heard some hissing in the engine compartment from my cab (close to dash, right side if I'm sitting in drivers seat). Shortly thereafter my heater takes forever to heat up (perhaps...
  18. LISA MACDONALD
    1996 2500 Low Beams and High Beams both out
    We have an old 1996 Ram 2500, the low beams haven't worked since we got it. We replaced the interior pull switch hoping that would fix the low beams. It never did, but high beams have worked fine this whole time. Last night I went to get groceries, and when I came out, the high beams had...
  19. 1LostRam
    help- isolated, coincidence, or MAJOR problem?
    I found another problem... First, some context. I may have let the excitement of a new lifted truck get the best of me; that but also saving on my monthly payment. I traded in and got this 2017 RAM Big Horn 5.7. It came with lift, tires and wheels. There were a couple of issues I discovered...
  20. P
    Steering Wheel Blinking
    2016 Ram 1500 Express/Classic. From day 1 horn has been quirky (works sometimes not others) - I assumed it was just a "Ram Thing". But... Now I have lights on the steering wheel blinking and horn either 1) does not work 2) works sometimes 3) gets stuck on (yep, good times rolling down the road...
  21. J
    2019 ram 1500 limited major problems
    I have a early production 2019 ram 1500 limited with the 12 inch screen and recently I've been having all sorts of problems. The problems have got worse and are now: screen and dash turn on for about 20 seconds when you start truck so no radio/ac controls, front windows dont roll down, defroster...
  22. E
    engine wont start 06 1500 hemi
    So yesterday after starting it the engine stoped after moving like 2 meters so checked the battery and everything and see that one of the copper terminals on the battery broke i tried stick the cables to the main terminal with locking pliers but nothing the cluster and everything works fine also...
  23. E
    Instrument Display problem
    I have a 2014 1500, single cab, 3.6 L V-6 that I just bought 2 months ago from the local Dodge dealer. I noticed an intermittent issue with my instrument display cluster, mainly when I use cruise control. When I tap my brake pedal to slow down , the display flashes back to display " Cruise...
  24. Orange whip
    Temp gauge not working.
    I replaced the coolant temp sensor and now the gauge goes right to hot when you start the car. I checked the wire connector with a tester and nothing. Anyone ever run into this issue.
  25. 802_6speed
    Gauge cluster backlight issue after tachometer fix
    So I just did the tachometer fix where you resolder two of the circuit boards, and it fixed the tachometer (it used to be 500-100 rpm off). Now I’m having an issue with the backlighting on the gauges and I’m wondering what I messed up. It seems that half of the backlights still work, and half...
