engineering
I am looking for some additional oil cooling capacity for my 2015 Supercharged V6. In general, the OEM system does remarkably well even under really heavy load - supercharged and pulling a trailer with at least one max gross weight limit reached.
The problem is when I am fully loaded, going uphill, high outside temps, and high-ish altitude. Oil temps will spike up to 260 if I am not paying attention. I usually slow down enough to keep it under 250. I would like to see it peak at 240 while going 55-60mph up a grade.
Discussion of modifications here: https://www.ramforum.com/threads/2015-pentastar-v6-towing-supercharger-success.171807/
I have the parts to add an additional radiator with driver/thermally controlled fans. That may or may not be enough.
Is anyone aware of an aftermarket oil cooler for the Pentastars? Maybe something that taps into the OEM oil filter/cooler and has a separate radiator? My preference is to setup the cooling system for the absolute worst case scenario considering a failure in the middle of nowhere with the whole family and a trailer.
