mopar68
There is a warranty that will run out in two years from today. It is only for the 4th generation rams. It is the rear gasoline strap mount that rots away causing the strap to slip and the tank to drop.
So if you have a 4th generation ram, get under the truck and see if yours needs to be replaced. Don't wait like I did cause nobody bothered to post this problem.
