Dean2
- Jun 17, 2021
- 2,928
- 4,537
- Location
- Near Edmonton
- 2021 2500
- 6.4
At what point do you just decide it is what it is and you don't have the ability to figure it out, even with a lot of help? You manually tested the gear ratio and got 3.55 and it is supposed to be 3.21. So is it really a 3.55 or did you measure and calculate wrong? Have you looked up the transmission gear ratios for your specific year and model of pickup. Do you know for sure none of that was changed, same with the front and rear gear ratios, because if the rear is a 3.55 and front is 3.21 you have a major problem.no it dosent. tries 4 different calcs.
Even when you put numbers in the calculator you get a different result than the rest of us? At some point, us trying to help remotely just doesn't work because nothing we do agrees with your numbers or measurements. Best of luck. Let us know if your ever figure it out.
