corneileous
- Joined
- Sep 6, 2016
- Posts
- 6,889
- Reaction score
- 3,930
- Location
- Podunkyville, OK
- Ram Year
- 2018 Ram 1500 Limited 4X4
- Engine
- Hemi 5.7
Yeah I forgot you were in Canada and already have your DRLs activated and Im pretty sure dedicated is what was chosen so have you like, put a mirror in front of your truck so you can see if the DRLs turn on as soon as you take the transmission out of Park? I say this because on my 2018 with DRL’s, they don’t activate until the transmission is moved out of Park. I’m not sure about how Jeeps work but it is very possible they could have those set up differently.Ok so I'm in canada so we have drl activated. Not sure what setting is in alfa just because I do have drl lights (yellow orange) turn signals..
Ok so if I want this strip to power on white when the vehicle starts what would I tap into ?
On my jeep as soon as I start it the led strip powers on and I'm tapped into drl it's a cherokee trailhawk. So I was thinking the ram would be the same.
But if you want the white DRL’s to work essentially like how your Jeep does, just get you a fuse tap and tap into the fuse in the fuse box under the hood that should be marked ignition coils.
But just so you know and probably unlike your Jeep, if you connect your DRLS that way, they’ll be on all the time, day and night.
