50BMG
Once again last night, I almost wrecked my truck in my own flippin' back yard while trying to back up the fairly steep incline on moist (just because of evening dew) grass.
These transfer cases, where the rear tires need to "slip" before the front tires get any power at all are THE most ******** things I have EVER seen on a supposedly 4WD drive vehicle in my life!
What retard ignoramus engineer designed such a feature!?! This person is so stupid he gives ******* a bad name! Probably the same idiot who gets the optional 32 gallon gas tanks to register "empty" when they still have 6 gallons of fuel in them!
Yes, I can see how this mode of operation might be necessary for the 4WD Auto feature/setting, but when I put my F'ing vehicle in 4WD LOCK OR especially if I need it to be in 4WD LOW gear ratio, I want the F'ing hubs to stay completely locked and I want 4WD ALWAYS to be engaged. I want 4 wheels spinning NOW when I apply some throttle take my foot off the brake. ALL my older Rams and even the 4X4 Fords I have owned operated this way, which is exactly how real 4WD should be.
Doing the simple "back up the hill" (going forward is the same issue) in my own back yard as I describe above is an F'ing nightmare, . Unless I whack the throttle and just go balls-out (which makes me likely to hit a tree or maybe even the corner of my house) this simple task can be nearly impossible to do.
Is there ANY way of getting rid of this ******** "rear-spin-first" delay to have 4 WHEEL POWER, ALL THE TIME/INSTANTANEOUSLY when I need it?!?
