Lube Job Stupidity
Medicman
California
4.7L
Hi everyone. I have never done a lube job before and my 2012 1500 needs one badly. I got a cheap lube gun from Harbor Freight and thought "how hard can this be?" I put the truck up on ramps and went crawling around under the front end suspension and could not find a single grease zirk fitting. Are these hidden under covers? I've read some are difficult to find but I'm totally surprised I couldn't find a single one. Any help is much appreciated. Thanks
Medicman
Medicman
California
4.7L
Thanks. My next question was to be "how do I get rid of the annoying squeaking?" I guess that'll be a rebuild. Thanks for the info.
chri5k
USA
Diesel
Depends on what is squeaking. Any clues to share about where the squeak is coming from?
mrack
Do you have leveling spacers on top of your struts, those are known to destroy your upper strut mount and cause squeaking.
Jeepwalker
WI
2012 Reg Cab, 4x4
FYI, don't lube the door hinges (I know you didn't say you were going to). They're a compressed graphite and brass compound..lubing makes them wear out early. I learned that on a Jeep yrs ago.:banghead:
You could lube the hood latch mechanism with a few drops of gear lube *if it needs it*. If/when I buy an older used vehicle in the rusty N here, I usually pull off the back of the rear driveshaft (at the diff), pull off the U-joint caps and add a little (compatible) grease in the two caps and compress with a C-clamp and reinstall. Compatible and compress are the key words. But in CA I doubt that'll be necessary at all.
If you don't know any history of the vehicle, probably a good idea to think about replacing the fluids. Or check them to see if they look pretty good. You could have the dealer service dept check the service history on it. Maybe the former owner had it serviced at the dealer and it's recorded in their system.
You can add a zerk to about anything, Google it. It is sad those days of actually lubing vehicles is gone.
Medicman
Medicman
California
4.7L
The squeaking, creaking sounds are usually heard when i'm driving slowly over a speed bump or entering a driveway, or sometimes when I'm stepping out of the truck. Sounds like it's coming from the front end. "MRACK" was right about the leveling spacers. I had those installed when I bought the truck back in 12/20. It's a "government" vehicle according to a check on my VIN. Thanks for all the info.
mrack
Take them off and make sure you replace both upper strut mounts. If you want to keep the leveled height, use bilstein 5100s or some sort of lift strut.
Docwagon1776
Midwest
If those are frame mount rock rails, make sure they aren't contacting the underside of the body. I had a similar squeak after coming down hard on one, didn't put two and two together until someone on this forum told me to check it.
Only the 4 wheel drive Generation 4 Rams have 1 zerk fitting, it is on the front shaft.
It is very difficult to see, it is different from zerks that you normally see
As far as i know,that's only on the 2500 and heavier trucks.
StateOfMind
Orange County CA
I had the front wheel off the other day, 4th gen rwd, and there was a zerk fitting on the UCA, near front bushing
StateOfMind
Orange County CA
That’s not a grease zerk, that’s a ball mount for the ride height sensor on trucks equipped with air ride.
Well that's a lesson that maybe I should wear my glasses more often. Thought it odd that it wasn't present near rear bushing on the UCA. thank you for the education
Stever68
Orlando, FL
If you find out what's squeaking pass it along please. Something in my suspension is squeaking and it is annoying the hell out of me
