raven3
- Oct 31, 2015
- 496
- 262
- Location
- Central CA
- 2015
- 5.7L Hemi RCSB Express
Would there be any interest in discussing the design features and operation of the Hemi MDS lifter?
Seems like folks complain about their noisy hemi.
Believe the noise stems from the lifters.
There are several engine cut a way views of the lifter & engine location, posted by Chrysler.
Understand the oil is supplied from the rockers and oil flow is from the rocker through the lifter to the camshaft lobe
with a hole in the push rod.
The oil supply to activate the lifter release pin and disable the lifter must be from the side of the lifter ,
since the pin access hole is located in the side of the lifter body.
Noticed the head of the pin and the oil supply hole in the lifter body are slightly off set, to capture the compression spring loaded pin.
