raven3
- Oct 31, 2015
- 496
- 262
- Location
- Central CA
- 2015
- 5.7L Hemi RCSB Express
From the cut a way views posted by Chrysler of the MDS lifter all the parts are assembled concentric to the axis, except the cross release pin with compression return spring.
Is it the cross pin that rotates inside the lifter body.
The lifter cut a way shows the pin head cap orientation aligned with the side hole in the lifter outer body part, but the pin is slightly lower, longitudinally, towards the roller end than the side hole. Oil pressure is applied to the pin cap end to push the pin cross wise to open up the oil chamber under the plunger so the plunger will travel back and forth inside the stationary sleeve with each revolution of the camshaft.
A depiction posted by Chrysler shows the entire valve train with all sixteen push rods. The lifters are positioned more horizontal than vertical.
So the plunger is concentric with the stationary support sleeve. The gravity force on the plunger actually creates a line contact on the sleeve,
Since in reality the two mating parts are eccentric caused by the difference in diameter.
The noise folks complain about is at idle when the lifter are supposed to be solid with no oil pressure applied to the release pin head in V8 mode.
The occilating plunger could produce a flat line area on both the plunger and sleeve, if the oil film is ruptured.
Agree with SYN that the oil must be maintained very clean with a minimum carbon particles suspended in the lubricating oil.
The source of the free carbon molecules comes from the combustion process.
