PUP 5W30- Not So Good, Not So Bad...
Richard Kim
Houston, Texas
Rotella Gas Truck Numbers (interesting that 0W20 is slightly thicker than 5W20 @ temp):
Shell Rotella Gas Truck0W205W205W30
Antiwear
Molybdenum150179160
Phosphorus623747676
Zinc766881807
Detergent
Boron8810492
Calcium117514611310
Magnesium449511446
Total Base Number5.96.496.78
cST Viscosity @100C8.78.511.7
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
6.4L HEMI
You guys in Canada can't get Amazon delivery from their Red Line Store?
ramffml
ramforum
I always got it from partsource, watched the flyers and waited for it on sale. But they didn't have it anywhere in stores for my last oil change.
JB's in Edmonton is Amazon's Redline supplier up here,and you can usually buy it cheaper off their shelves,and most times Mopac will beat JB's price.Both are old school brick and mortar speed shops in western Canada
DILLIGAF
Canada
My Local parts store get it for me from JB at a better deal. :cool: still 75$per gallon tho! :(
Im thinking that I could use 1 gallon of RL 5w30 and the other couple liters I might just add PUP 5w30 for top up...
This is the cheap Frenchmen talking out loud here...lol...
I just tried the Amsoil Canada Oil analyst service for my PUP 5w30 that I just dumped. Hoping my Cam is breaking in nice after the unfortunate start up **** up on my part. :crazy:
DB Cooper
Califor
5.7 ETORQ
I had made my first oil change a few weeks ago. I didn't like how thin the 5/20 was and plan to switch over to 5/30 at the next change. I was also shocked that the drain bolt was barely finger tight.
DILLIGAF
Canada
Our country is ran by a bunch of clowns, printing money to send to Ukraine because " WOKE reasons "
It so bad up here that im now a criminal because I sure as **** wont turn in my AR. and now the sock puppet decided to ban pistols that I wont turn in either...lol..
Served my Country for 22y , Was given guns to go fight illegal wars over natural resources. But when it comes down to me protecting my own castle im SOL and a extremist.
But I wouldn't expect anything less from those pedos. They can all suck my ****.
Yardbird
Western NC
I'm not totally sold on 5W20 either. I'm using it in my wife's Edge, and that's what is in my Ram.
But, looking at the numbers posted, it seems 5W20 has some good amounts of ingredients.
According to prior owner, PUP 5/20 is all that's been in this truck since I got it at 24k miles (besides factory fill). I'm still deciding what I' going to do. Thinking of 5/20 Castrol Edge like I have in the wife's car. It meets factory specs.
HEMIMANN
Minneapolis, MN
6.4L HEMI
5/20 is only another minuscule attempt to save a little gas at the expense of faster engine wear, if you use the truck as a truck.
If it's just a grocery getter hauling cotton balls, it won't matter.
I run 5W-30. I tow moderate.loads.
Govtman
Oklahoma
I noticed something similar. I switched from royal purple 5w20 to 5w30. Didn’t notice anything different until I switched back to mobil1 5w20. The biggest difference was going into and out of MDS. Much smoother with the 5w20
I started dropping out of the eco while driving and my gas mileage has increased.
Hydrasport23
Mississippi
5W-anything is the same "thickness" (viscosity) as 5W-anything when the oils are cold. The 20 viscosity will be thinner than the 30 viscosity when the oil is hot. Is your oil pressure that much higher when running the 5W-30 oil when hot than when running the 5W-20? While it takes horsepower to make oil pressure, if the oil pressure is only 2 or 3 psi higher between the two oils, I doubt you will notice any horsepower loss.
Your oil temp should be a bit hotter than than the engine coolant because the oil does a lot to cool an engine.
G
Greg0517
Canada
I find Canadian Tire always has the best sales on PUP every 3-6 weeks!
HEMIMANN
Minneapolis, MN
6.4L HEMI
No, it's not. SAE viscosity grades cover a fairly wide range of viscosities. Google it.
