Zane2014
I have had my 2014 V6 for almost 7 years it has been moderately reliable, minus the oil cooler blowing a couple years back. Now out of the blue right before I am supposed to move it gets the red lightning bolt of death. Just happened out of the blue, if I am driving it will randomly go into limp mode and the dash will light up like a Christmas tree with every error message known to man popping up. Seems to happen more on rough roads but really just random. My first thought was a faulty TIPM but after replacement it still is happening. Checked wiring harnesses doing wiggle tests for hours. Checked grounds. Having done weeks researching and trying to diagnosis I haven't gotten much of anywhere. Anyone have a crazy electrical gremlins like this before and find a fix? Any help is much appreciated, driving me absolutely crazy. Just a laundry list of CAN bus and implausible data. I have autel scan tool which usually helps but these rams seem to be very finicky.
Here is a list of the codes.
U1424-00 – Implausible engine torque signal received (Stored)
ABS (Anti Lock Brakes) – 4 DTCs:
B0020-13 – Left side seat deployment squib 1 – circuit open (Active)
IPC (Instrument Panel Cluster) – 2 DTCs:
U0002-00 – CAN C bus off performance (Stored)
- U0401-00 – Implausible data received from ECM/PCM (Stored)
- C121C-00 – Torque request signal denied (Stored)
- U0002-88 – CAN C bus off performance - bus off (Stored)
- C2100-16 – Battery voltage low – circuit voltage below threshold (Active)
- U0001-00 – CAN C bus (Stored)
- U0002-00 – CAN C bus off performance (Stored)
- B2312-15 – Wiper On/Off control – circuit short to battery or open (Stored)
- B16B7-15 – Center stop lamp control – circuit short to battery or open (Active)
- B1F07-00 – Auxiliary switch bank module internal (Stored)
- B222C-00 – Vehicle configuration not programmed (Stored)
- U0019-88 – CAN B bus – bus off (Active)
- U0415-00 – Invalid data received from anti-lock brake system (ABS) control module "A" (Active)
- C2128-00 – ECU reset/recovery occurred (Stored)
