All
Just purchased an aftermarket LED third brake light for my 2014 1500. I have been reading about the leaks around this area of the truck, and was wondering if i should replace the gasket that came with the unit with a better one or if the one that came with the unit is good enough. I am not experiencing any issues and it does not appear that the previous owner has had any either, as i could not see anywhere that water has entered the cab. Also, would you recommend any of the aftermarket tail and headlight setups? I am looking at Spyder and Recon.
thanks in advance.
thanks in advance.
