Many members believe if you get caught changing anything with AlfaOBD, your entire warranty with FCA will become null & void.
I've read about members who believe that if you so much as get caught with a bypass cable installed, your vehicle will be flagged and the warranty voided.
When I purchased my truck in January '22, the sales manager insisted (right or wrong) that there would be no grief with anything I changed and no impact on the warranty.
However, if my alterations caused a failure, that would be my problem and I would not get any warranty for that item.
My KaodTech bypass cable has never been removed since the day I installed it, I keep it tucked away under the dash and have not altered the OEM OBDii port.
I'm not overly concerned about my warranty being voided because I chose to make a few configuration changes but that is your decision to make for your truck.
I'm not familiar with any settings or changes to the brow lights, my truck is browless.
I have made changes with AlfaOBD so that my DRLs are an option in the radio menu and have the ability to turn them on or off. The default DRL for my truck is front signal lights.
The DRL are always enabled and I have the dashboard light sensor covered with black electrical tape so that the headlights come on when the sun gets low.
IIRC, I made the following changes to DRL settings;
Switched from Canada DRL to Optional DRL.
Cust.set.menu 1 -Daytime running lights CSM present /yes
And, drl/ ECUConfig 3 -Customer setting option present/ yes.
