TheEnder
- Aug 12, 2017
- 2,093
- 1,647
- 2013
- 4.7L V8
Hello, this is my experience with LTF, i’m making this so people can learn and fix their vehicles if they have tranny issues that aren’t catastrophically bad.
A few days ago i decided to pick up LTF from O’reillys. At the time my Torque Converter loved to make a rattling noise at around 1300-1500 RPM, which i thought was just normal 65RFE behavior.
Also, the truck loved to “slip” (it never really felt like it was slipping.) on drives. What i mean by this is that the truck would shift just fine coming off from a stop, but slowing down and then re-accelerating would cause the engine to just stay at around 1500-1900 RPMs until it eventually shifted into a lower gear, but during it staying at 1500-1900 it would gain speed with no problems.
I dropped LTF into the transmission fill check tube (2 bottles, one isn’t enough for the 65RFE) and immediately it was a huge difference. The rattling is completely gone, and it seems the shifts are a lot more firm and less slushy. It kinda helped the previously mentioned “slipping”, but to me, i think that’s just how every 65RFE acts.
Regarding temperatures, the transmission still never goes above 130, and the highest it’s recently been was 129, and that was just after adding it.
Regarding fluid levels, Yes, it does rise. But it’s okay. Lucas is designed for this. It stops tranny leaks, contains friction modifiers to improve the grip between clutch plates inside the transmission, and also creates a polymeric film on the transmission bands to help prevent slipping, and removes sludge in the valve body to help out shifting even more.
Hope this helps anyone out that comes across it. Thank you.
Sent from my iPhone XS Max in my 2013 Magnum 4.7L V8
